jrjulien1
i was delivering papers the other day as its my job and i saw an old dirtbike frame at a persons house and it gave me an idea if i could get a dirtbike frame with the tires still on it most of the older ones have drum brakes in the rear and a seat so all you would have to do is get an engine and mount it on the frame by welding on a plate with holes in it and use a centrifugal clutch and if the rear sprocket dosent match the chain size of the clutch just use a small jackshaft to modify the chain size the only problem is that you would have to lock up the rear suspension with a metal bar cut to legnth with holes in it
just an idea
just an idea
