Aluminum Vs Billet Flywheel?
solomon
ca
Same thing, Billet, refers to a "block" of metal that was cut down to the flywheel.
The term "billet" means that the part in question (like solomon and kaptain said) was machined from a solid piece of stock. The term is usually used when referring to aluminum, but sometimes steel, too. So when you say "billet OR aluminum", we will assume you mean billet aluminum vs. cast or otherwise formed aluminum. Billet is a generally the better choice, as there are no casting defects in an item that wasn't cast. There's better control in the manufacturing process, and the part is much more likely to perform. I'll also cost you a fair bit more. In the case of a flywhell, sure, go billet if you can afford it. For say, a rearview mirror- save your bread.
newrider3
Colorado
Buy the billet if you can afford it, even if it is a bit heavier. IMO it is worth the extra safety. Some here will say a flywheel will never explode in our usage; I'm not about to open that can of worms again. But ask any old kart racer and see what he says.
mike75925
thinker and tinkerer
Alto, tx
not sure how they get the chunks of aluminum they use for billet items, but it would seem they have their own casting. aluminum does not come in blocks. the method of casting the billets is likely done in a more scientific manner along the lines of no air/vacuum being drawn in the 'casting chamber'. is billet just the grain running in one direction, or is it like plywood where the grain runs in multiple directions to give it more strength at various angles?
mike75925
Alto, tx
is it done like making bread then? the metal being slowly poured into a 'pan'? grain forms naturally, but do they have to pour in sections to get the build up of layers? is the vessel cooled to aid in making these layers? or is it simply like the play-doh machines that do spaghetti and such. wherein the molten material is squeezed through a particular opening and whatever the opening's shape, that is what the metal is? it seems the best method, though it would have to be refined so much more than the cast quality metal.
mike75925
Alto, tx
seems they would save a ton of time and money by actually melting the aluminum rather than crushing it through an orifice. the stretching step seems like it would break the grain and make it weaker. i watched a show once where they mixed up some sort of epoxy and drew it down it a vacuum chamber to remove the air. the resulting product had very few if any air bubbles on the molded surface. when a tree is cut into lumber, they don't stretch it, they just send it through the saws, and voila, a billet. the force it takes to crush aluminum on that scale has to be tremendous. and it would seem a reason to keep toolers employed.
KieranM
Doin It!!
Kilkenny, Ireland
dpaxson
parma heights, oh
the extrusion process work hardens the metal i believe. forged parts are much stronger than cast parts for the same reason. also, to a big enough hydrualic cylinder, aluminum at 800º seems like butter
newrider3
Colorado
seems they would save a ton of time and money by actually melting the aluminum rather than crushing it through an orifice. .
Then it would still be cast, and there would be zero difference between the stocker besides extra machining.
How do you think tubing or sheetmetal is made?
