This one's a little outta my department, so if you know anyhthing here, feel free to throw it in!
As many of you know, I'm plugging away at a racing mower build. I have recently torn down a parts engine, and was examining the flywheel. I had a though- which occurs occasionally...
I'm quite restricted in what I can do to the engine in this build class, so I'm examining a two-fold "cheat".
We all know that a lighter flywheel allows an engine to spin up a wee bit easier. Now look at all those BIG magnets! What if I remove them? It will lighten the flywheel a bit...
Now, the question- By removing the magnets and therefore eliminating the alternator, is that going to free up a fraction of a pony? I have absolutely no idea how much drag the alternator creates... But I do know that I don't need a charging system for racing. The rules state that I have to have a functional starter- they don't say anything about not being able to manually charge the battery between races!!!
Is it worth doing?
EDIT- There are 12 magnets, I circled one in red.
Is it worth doing?
Why don't you just whip out your race prepping bench dyno and do some pulls and let us know how it works out!!
to get out is a given). Does this use the Ignition coil for the voltage pick off or does it have a separate coil for charging? Remove the coil, and you should remove any chance of adding drag. Just my
oh wait this is supposed to be a
race motor?
Any decision, Yea or Nea?
