alright yall
johnboggs21
Ive got a 4 horse briggs off a push mower mounted in a murray mower that i use as a snow pusher and to tug trailers. I need to get as much power as i can outta this thing without blowing it up or emptying my wallet. any ideas?
crazycart
RedNek Engineering
MINNESOTA
Yup no problem. You can also re-gear it for that low end power your gunna need. I also recommend tire chains and weights. But, now that i think about it, that 4hp was off a lawnmower-not exactly a powerhouse for a actual tractor. Id recommend a bigger engine. Search craigslist.com for a vertical shaft engine, they go very cheap.
johnboggs21
well i plowed with it all last year it just was slow goin.lol i got quite a bit of weight and chains on it. problem was if it hit a tough spot it would stall the engine.
crazycart
RedNek Engineering
MINNESOTA
Yeah id go with a bit bigger engine, people even throw these vert. shafts away. They are all over for cheap. You can mod that 4hp, but there's only so much you can do on a budget and keep it reliable.Most mods done to these are for higher RPM and not just to chug along at a bit more than idle speed.
johnboggs21
ive got a 8 horse to rebuild and put on there but thats on hold for now. i was just hoping to be able to get by this winter with what ive got.
crazycart
RedNek Engineering
MINNESOTA
Well i would just take the head off and clean up the ports with a dremel, grind off the eyebrows, set the idle a bit higher, maybe get a good header pipe, and you'd be set.
johnboggs21
sounds like a good deal. ill keep checking back here in case anyone else has any ideas or if you think of something else.
thanks
johnboggs21
its got a peerless transaxle. it will only stall if i hit something solid under the snow. like frozen snow from last time i plowed and sometimes if theirs a lot of snow.
Kenny_McCormic
Kartless....
Michigan Troll
I beat the **** out of a craftsman with a 8hp swap for several years, it was unstoppable, but when it got unsteerable i scrapped it out and put the motor on a different mower that came with a blown 12.5hp motor just like the craftsman.
johnboggs21
was it a briggs?
