Almost completed Buggy Project!! Need help
Texas
I am purchasing the engine tomorrow (750cc v twin honda bike engine) i need to know the gear setup... i have 20 inch rear tires. Anyone know what i can do?
fowler
Bullsbrook West Aus
U have seriously limited info
U need to tell us the buggy type
Engine type
Hp output
Weight
A buggy has different gearing to a kart
I'd just go a few teeth added to the stock size off the original bike
Texas
It is approx 31 hp and puts out 8500 rpm and weighs 110 (engine) with buggy Fully loaded i would probably say 650 (roughly) thats with 2 people.
Texas
its off of an older bike, this is what the owner of the junkyard told me, but he didn't know much, and i don't know much about gas engines, so this puts me in quite a bind, its liquid cooled and i think its off of a 1980ish bike, but im not promising anything,
fowler
Bullsbrook West Aus
Naaa post pics
Try to find some serial numbers
A wreaked tryed to tell me plastic ally radiator was off a 1960s car
They don't care about the info just the sale
Sorry for the trouble but if u really have a 31 hp engine then the gearing changes dramatically
Honestly- If we don't know anything, we can't tell you anything. Not much anyhow. If it's an '80s Honda Vtwin 750, it SHOULD be from a Shadow or Sabre (or was that the Magna?) Depending on which one, it will be either chain drive, or shaft drive. If it's shaft, you'd better be handy. And it's be worth more than 30 hp. We're talking 45CID displacement here.
Yeah- Don't buy anything until you know what you're dealing with. This is a rip-off waiting to happen. It's coming from junkyard, seller knows squat about it, and you don't have the know-how to determine if it's a paperweight or not. Don't do it.
fowler
Bullsbrook West Aus
Still for interest have u got pics of the engine and the buggy
I'd just start with 8 more teeth than what the original bike had
So if it was 14 32 it is 14 40
Texas
Okay. It has the stock sprocket on the engine, Which im guessing was a 14, but i bought a 40..
Now I just need to know where i can get a wiring diagram, The wires are everywhere, the man who sold it to me disconnected them ALL. . If i could get one online, anyone know where?
kaymo
hickory nc
dude, you need to look for honda bike stuff... this may not be the place for that info....
and for gosh sake post pics or it didnt happen
1) Don't guess on sprockets, count teeth and do the math. Saves you from regearing later 'cause you missed the first time
2) Scour the 'net- wiring diagrams are available all over the place. Failing that, buy a service manual.
3) Keep asking questions. I've got a couple of older Honda bikes floating around here, you never know what information you may find, and from whom.
fowler
Bullsbrook West Aus
assuming i filled this out right
http://www.bikerenews.com/Stories_Archives/GearRpmSpeedCalculator.htm
Gear ratios in the transmission are as follows:
1st gear: 3.166
2nd gear: 2.000
3rd gear: 1.500
4th gear: 1.173
5th gear: 1.041
i put the primary drive as 1???
u are looking at closer to a 60/70 tooth to drop the speed to 60mph if u keep the 14 tooth front sprocket
with will be plenty fast enough and more than halving the speed should be enough torque
Texas
Okay, got the motor running, has a very small oil leak, and carbs could use a good cleaning. But this is not a honda shadow V-Twin. It has 4 spark plugs, which to my knowledge means 4 cylinders. Unless they made backup plugs, which would make no sense..
I'll have to go out back later, but I believe the VT750c Shadow DOES use a second plug (per cylinder). You should be able to tell just by looking at it how many cylinders it has. Try looking at the exhausts, for example, or intake manifold routing. And- Like Fowler suggested- Got a camera???
EDIT Yes, the VT750c does use two plugs per cylinder- I don't know much about it, but I imagine it's a waste-spark type system. There's 2 coils on the bike, and each coil feeds the main plug for the one cylinder, and the "second" plug for the other cylinder. Maybe I'll shoot a pic later.
