How/where would you put the center diff? Maybe on a jackshaft somewhere in the middle? Where will you mount the motor?
Right now, all of these dimensions (and there are TONS of dimensions on that project) are approximate. The only thing I'm mostly sure about at this point is the axles will most likely be an inch thick. My huge hurdle is that I don't currently know how to weld, but I'm trying to save up for a welder so I can learn. I also am having the hardest time finding a welder at all (which is why I'm trying to purchase one). I even have a good friend who is wanting to practice welding (was planned to be the welder as per my ideas), but between us, we can't find someone who'd let us use theirs--or anyone with a welder at all.
I also don't have any of the crucial parts. The actual size and shape of the differentials I get ahold of will determine where they will need to be mounted for things to all line up. The actual CV joint I get might determine how wide my kart ends up being, unless they're just too wide or too narrow that I'd have to cut them or extend them. I don't have any clue what the dimensions are on a 250cc 2stroke engine. If anyone could just get me the dimensions of a box that it barely fits in, would be a lot of help in the design phase.
Lots of things will be decided in the garage rather than the office. I'm drawing up more of a "best-case-scenario"/Optimal type drawing. I did calculate a 40" between front and rear wheel centers, and 35" between the centers of the front wheels, which, according to ackerman steering geometry principles, would require the front steering control arms to be at a 66.37degree angle. I'll try to stick to my wheelbase more than anything. I want it to be close to square, but the width will be no less than 3/4 the length. I'll make the steering control arms adjustable, so I can use it to learn more about ackerman steering principles as they apply to performance later on.
That is what it might look like without the chain, if I were to use chain drive. The more I think about it, The more I like the idea.
Good news, it looks like I'm going to get away with about $25-$30 per differential.
I also might not ever put any suspension on it. It can't make too big of a difference on pavement. Which, theo, you're right. I bet it would be easier to go without the u-joints.
I've done some calculations via the program to find the mass of the frame should be around 25lbs. This is very hard to be accurate with. But is probably within 5lbs.
Anyone think it'd be outrageous to think that I could have a 100lb cart?
If so, scaling top speeds claimed by others on the internet that have bikes with 250cc two-stroke engines, I should be able to do 80.
