Airbornejordans project kart
AirborneJordan
USA, OHIO
Well, where to start....so I am an avid tinkerer and have been a professional "backyard" mechanic for a long time. I have a lot of back ground In Engines. When I was much younger I had a go kart with 3hp Briggs and Stratton. I was all was messing with it and developed my love for go karts. Now that I have few kids of my owne decided to pick up a project. So it begins...
Sent from my SPH-L720 using Tapatalk
AirborneJordan
USA, OHIO
Found this gem on Craigslist, and picked it up for 180$.
Not sure on the motor....only sticker says displacemen 173.
Maybe 5hp.?
AirborneJordan
USA, OHIO
Well.. the bad news is that it needs way more work than i thought at first. It has a flat front tire, it burns up belts, needs a carb clean and adjusted(will not idle). Found a bent rear axle.Along with other maintenance. Someone put 21" tires on the rear. I love Em but wow no wonder it burns up belts.. The engine runs ok...
AirborneJordan
USA, OHIO
My plan with this kart is to set up for my 5 yr old daughter to drive off road. We spend a lot of time in the woods with my quad and the samurai. I figured it was about time for her to learn to drive. I am wanting to turn it Into a 2 seater(buckets) and put some suspension on the rear. SO let's get to some progress...
AirborneJordan
USA, OHIO
The first things first ..getting the clutch and driver cleaned. It is a comet 30 I am pretty sure.. During the cleaning here is what I found.
Notice the slider pins are out of place and ride on top instead on in.
Then I took it apart and found 2 different sized springs.
This clutch is also missing the brass bushing. I haven't measured but I am pretty sure it is 3/4" shaft. The slider cam only has 4 splines.
AirborneJordan
USA, OHIO
I got the clutch and driver all cleaned up. I got them in good alignment. It was off by a 1/4 inch. I think it is OK now..
But I am concern about this.
There is not much shaft for the driver to go on to. Is this ok?
AirborneJordan
USA, OHIO
So once I got the clutches taken care of..went for a test ride...
It works much better. But not up to par yet. It is still burning belts but 60% less.. here is the new belt after about 15 min ride.
That can't be right...I will guess that the gear ratio is way out causing it? I have a 9 tooth at the motor and a 54 sprocket. With 21 inch tires. Only 173cc to turn it.
AirborneJordan
USA, OHIO
I am open to suggestions on this topic..I have few ideas but am Un decided on what to do. I will most likely go with a smaller 18-19 inch tire just more tread. I am thinking about getting a predator 212cc. I get one now for about 80 bucks. Is the extra 40cc worth it? Or should I just go for more gears? Like a 8 at the shaft and a 60 sprocket? Remember, I am not after speed. I need torqu to get down the trails in the woods.
My first suggestion would be to use the Edit button on the bottom right of each post. This means that you then do not need to double and triple post just minutes apart.
Secondly, I would DEFINATELY get rid of those big tyres. They are killing your belt and TC. Unless you gear seriously lower than what you are (6:1), you are always going to have problems. I would swap the axle sprocket out to a 74T. That should be adequite (I think) for your tyres.
Are you also sure that you have the correct belt. You might have a 30 series belt, but is it the right one? It could be too tight. Measure the center to center distance of the driver and driven and check out this chart for belts
http://www.gokartsupply.com/tcbelts.htm
AirborneJordan
USA, OHIO
Thanks for the great suggestion. This will really Contribute to the build thread and help others that are looking for answers to their questions. Good job on being the forum police.
AirborneJordan
USA, OHIO
So..anyone else have advice on..keep the 172cc motor and change the gears or pick up a new predator 212cc? Would 40cc be a large improvement?
Either way I will still get new tires. Looking at 18" or so.
gman3850
gilbert az
the 172 is like a 5.5hp and the new hemi 212 is a 7hp. Plus with a air filter adapter 140 e tube and jet accordingly + header youll be at 9-10hp. I have it is my 2 seater with 20x10-8 and it moves it quite well and i dont eat up that many belts.
If you do that and a 6:1 ratio you can keep the bigger tires in the rear
I agree
