Air powered secateurs
fowler
Bullsbrook West Aus
so i found a small pneumatic cylinder at work
it may not be big enough
but now the idea is seeded so its happening
if its under powered i'll source a bigger one
my first step is to convert a cheapy manual set
im sure iv got it sorted but iv confused myself with not loosing too much mechanical advantage
pic one is how a factory set works
but i think pic two will retain the advantage by retaining the scissor
alternately if anyone else has a better idea come forth
the biggest issue is using a cylinder to actuate it must be a push action to close them
i have around 6in of stroke making it fairly easy
No need to cut anything...
just remove the lower nylock nut, swing the arm above the upper handle
and attach your pneumatic cylinder to it.
the lever is a bit short if you ask me, so maybe you want to replace the lever with a slightly longer one,
but after all.. that lever above the handle will close the blades if pushed forward.
[EDIT]
made a quick and dirty photoshop mockup
same principle (just a longer lever ;))
to this:
