Air filter housing fix
ballinchestr
Grease Monkey
Massachusetts
While working today, I accidentally smacked the air filter/housing off my engine. it looks like the base and the filter housing are 2 separate pieces glued together, and the glue was faulty. the part that broke off contains the actual filter so I can't run until I reattach this. What I need to know is should I get a whole new filter setup, or glue the filter housing back on. If I choose the latter, what type of glue should I use? I have watertight adhesive from loctite, general super glue, and hot glue. which should I choose? My engine is the 212cc Predator.
ballinchestr
Grease Monkey
Massachusetts
Okay, I noticed that the old glue and seal were dissolved or corroded by something, which caused the failure. should I be worried about a gas leak? The engine was tipped on it's side at one point, like a month ago.
Let see some pics, I kinda think I understand. Hot glue I think would work but the fuel might dissolve it. If anything epoxy would be the best.
buckwheat
Lilburn, GA
I have had good results using a hot melt glue & gun to fix platic parts. Get the joint and surrounding area clean with a good solvent.
edgeblade
Any idea on what exact aftermarket aircleaner would be needed for a 212cc predator engine?...also a link would be nice....sorry if I hijacked your thread but my aircleaner just did the same thing...thanks
