ahhh leaking drops of oil out head
rebuild
I have robin and its my first engine rebuild every time I run it leaks oil
r_chez_08
Should be in the shop...
Cornwall, UK
Where exactly?
Ohv, ohc or flat head?
It could be a number of things.
Oil level, valves, gaskets, rings, bore. Maybe more.
Does it have blue smoke?
It shouldnt leak from the head, that's what the gasket is for. Pics?
If it is from the rocker cover, then try a new gasket.
The rings should have a clearance of a few thou. (.005" or so)
Have you got a feeler gauge?
