AGK Stage 2 engines
ChefJKerr
Does anyone know anything about these motors? would it work in and Off Road Murray Kilowatt?
Stage 2 Engine
Stage 2 Engine Quantity in Basket: 1
Code: Stage 2 Engine
Price: $526.00
Choose Header:
Quantity:
Stage 2 engine: *high flow air filter with adapter *#92 main jet *18lb valve springs *breather filter *billet connecting rod *aluminum flywheel w/4* advance *choice of header All our engines have the govenor and low oil sensor removed. Some parts may not be assembled on the engine for shipping purposes. You need to add oil before running the engine. Contact us if you need break in instructions. No warranties or returns on racing engines. Stage 2 engine pictured with candy cane header.
anderkart
Surprise Arizona USA
Yeah, that AGK engine would work great in yer Murray. Its pricey, but has quite a few goodies so it would probably hold up to 6000+rpm riding for quite awhile.
Arc has a lower cost-engine package you should consider too} http://www.arcracing.com/servlet/the-5/Box-Stock-Project-BSP/Detail
You'd just have to order your header/air cleaner separately, and it comes with a stock flywheel and rod.
Its also set up for a remote fuel tank so that might be an issue for ya... But these yellow Dupor-brand engines that Arc sells are known (by most kart-racers) to be a higher quality copy of the honda GX200 than the blue ones that AGK and Harbor Freight sold.
