SWINEMOTHER
- Messages
- 3
- Reaction score
- 0
Alright, so been lurkin here for a while but have never had need to post until now.
Currently working on a project that will require multi-staged gearing. Background on the project:
Found an old e-ton 50 out in a pile of scrap while renovating my shop. Engine and transmission were worthless, but the frame and tires were in great condition. Decided to pull the engine and attempt to pop an extra predator 212 I had laying around in there. Due to the drive rotation of the engine and the side the rear wheel sprocket is on, I opted to run my drive chain back and transfer it across via a jackshaft. The problem arose when i realized that I would be fielding a theoretical 40+ mph machine into the hands of a 9 year old if I used the 10>10>10>28 gearing. In order that's cvt drive>jackshaft input>jackshaft output>rear wheel. The tires are 16in. Played around with the various ratios a bit and sort of settled on 8>12>8>36.
This, if I have the math right, would allow me to run the engine up close to the normal 3600ish rpm, reducing the rpm of the jackshaft to 2400rpm, which in turn would give me roughly 25 mph at full throttle through the 8t to 36t ratio. Moving the throttle stop in to derate to 3000 shaves another 4ish mph off. Potentially might further reduce rpm limit to 2500 to sit just under 18 theoretical mph.
Real question is is there any detriment to multi-staging such large gear reductions? sprocket damage, etc.
Thoughts and comments appreciated.
