Advice on mixture and general engine performance
raposak
2012 Build-Off Winner
Howell, NJ
Hello all,
Well I made my custom exhaust this weekend and was able to get it into the dirt for some testing. I ran it about an hour before bringing it home to get the following readings.
First the exhaust:
Now the plug:
I think I may be running a little lean. Do you think I should open the jet up a little? Also, I'm not getting the rpm's that I thought I should. Its a duromax 16hp with the the governor removed. I'm running a comet 40 with a 9t jackshaft and 54t axle sprocket with 22" tires in the back. Any advice would be appreciated.
raposak
Howell, NJ
Ok thanks. I guess I should get a smaller sprocket for the axle than since the front is already small enough. If I have a 54t now, what would you suggest I go down to? Also, will this also allow the motor to rev higher? I'm off to harbor freight to get some new drill bits.
No- larger axle sprocket will equal a lower gear ratio to unload the engine and increase max RPM.
Your ideal ratio is a bit tough to project right now, as we have no idea what kind of RPM you are currently attaining. You're in a trial-and-error stage right now. If I were you, I'd next try a 60T rear, which will bring you from 6:1 to 6.66:1.
Limited slip? Are you sure? What did it come from? Maybe it's a standard open diff?
Anyway, I don't know where to point you for a sprocket- I apologize- I just had no idea you could get an LSD for a kart...
raposak
Howell, NJ
It was on it when I bought the cart. When you lift the back of the cart and spin 1 wheel, the other wheel turns in the opposite direction.
raposak
Howell, NJ
It's open even though when giving it gas both wheels spin? I thought that an open diff meant that only 1 wheel has power.
No- An open diff will deliver power to both wheels more or less equally when traction is more or less equal on both sides. The $50 test basically boils down to this-
Block up the frame so one wheel is off the ground. Get in and increase the throttle. If it's an LSD, sooner or later the increasing RPM will overcome the diff's preload and the kart will begin to move. If it's an open diff, the wheel in the air will spin like he//, but no amount of throttle will get you moving.
raposak
Howell, NJ
Ok, i'll give it a try. Thanks for the info. Do you think it would be worth it to totally swap out the rear axle for a solid one? I'm sure if this is in fact an open diff, than off road performance will suffer. I can probably get away with reusing my brakes and such.
Bluethunder3320
what # of teeth is on the sprocket on the jackshaft? if its a 10t, you could try a 9t, and this might be enough to let the engine rev high enough.
with a TC in general you wont see over 4k rpm because it keeps a load on the engine the whole time.
also you can fill that diff with SUPER thick grease, this will make it more like an LSD because it will have more resistance for the gears to move inside it.
72t may work (you will have lower ground clearance) and if thats a little too low, you can always put a bigger sprocket on the jackshaft like a 11t or 12t.
bigger rear sprocket lowers gearing.
smaller jackshaft sprocket lowers gearing.
EDIT: you need a bigger main jet too. im not sure what jets the 16hp's use since im used to the 6.5's, maybe someone else can tell you what to try next.
raposak
Howell, NJ
I already have a 9T on the shaft. I think I will bite the bullet and replace the entire axle with a solid 1". That way I have more options. I still can use my existing hubs and brakes so it wouldn't cost much.
I also drilled out the jet and from my initial plug readings, it pretty good now.
I'd bet that it's not an LSD. Based on that, yes- switch to a standard live axle. Big performance improvement, especially in lower traction conditions. He//, once my kids get used to things, I'll be deleting the diff in their kart, too.
