Adjusting Hydraulic Brakes
At least you spelled brake correctly. Well done, well done!
On the other hand, I don't see a question here, just a statement. Brakes do cause friction--yes indeed. Carry on my good man (or woman), carry on.
very likely you mounted the caliper incorrectly..
or to a disc that's too wide for the caliper you have.
the caliper must sit perfectly parallel to the disc (of course!)
and since that's a floating single piston caliper,
it's guide rods need to be perfectly clean and free of dents in order to not lock up on you when the brake is released.
Or worse you haven't considered for it's lateral movement with your mounting position.
So yeah, pics of YOUR caliper from a good telling angle.
best two.. with engaged and released brakes ;)
Joe-405
Enjoying New Projects
U.S.A.
And this is where we say welcome to the forums ! We are always here to serve and protect punctuation. Lol
By all means, welcome to the forum just like Joe-405 said. All in good fun. ;)
However, we must insist on at least one decent photo of your problem area because pictures speak a thousand words (and all at once).
kouroshs123
Alright thanks for correcting my ****ing typo I was in a hurry and had some work to do. However I fixed my problem. Since I was lazy I just decided to floor my kart and engaged my brakes at the same time until the brake pads wore down and were aligned.
Problem solving at its finest.
Poboy kartman
Senior Moments Member
White Settlement Texas
AWESOME....(there are a few members here that I wish "breaks":lolgoku:....would fail...)
Carry on my friend....and stick around....this place just gets funner and funner....(I think I spelled it write...butt...it jest sounds wrong? ) Funner? FR?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
It's Most more Funnerest...
Expecially now that the tread title has bin fixt, and nun of dis makes any cents!
Damian Laffrey
Chennai City , India
Brother, if you dont want to wate time, or money ....go for the braking kit from a singke machine. It saves you time when u install brakes from a motorcycle or something. There wont be any complications. My sugession...take your brakes to a mechanic and ask him advise to find a effective replacement so you can carry on with your project. ALL THE BEST
