I don't know for what carb.
But if for a Honda or Honda Clone, An oversized jet is screwed in the main tube of the carb.
The screw/bolt that holds the float bowl on is replaced with a Bolt/Needle where the needle tip fits into the jet. Screw the needle tip tighter into the jet to lean the mix out. Unscrew the needle so it is not as tight into the jet to enrichen the mix.
I have never used one, but I saw a cheap one on ebay IIRC.
Reviews said the adjustments needed to be finer and the needle tip needed to be sharper. I'm guesssing NR's is better than the ebay homemade one.
