Adding a alternater to a predator 212
fast92rs
Old Bridge, NJ
Can a predator 212 be fitted with a alternater from a similar engine? I want to run led lights on my new project and I'd like to have constant power instead of just using a battery alone.
JoshTehSquash
I want to do this too. Couldn't you just turn the alternator off of a jackshaft set to spin at the right rpm?
fast92rs
Old Bridge, NJ
After googling and YouTube tge answer is maybe lol. It depends on what version of the 212 you have. It seems the newer versions some came with lighting coils already. But if want to add a coil you need to have the mounting holes behind the flywheel for the coil and apparently any honda gx 200 clone 3 magnet flywheel will work. I found a coil for the 212 on monster's web site and a gx200 clone flywheel. So I have to check mine later and see if I can add it or it already has it.
The Honda engines (& all other small engines) don't use an alternator, they use a stator (same concept, slightly different application); the stator setup is attached behind (read inside) the flywheel...
As there are some engines available with all the electric start gear, you wouldn't think the same engine without E/S would be much different, meaning, the space for the hardware, as well as the mounting holes, etc, should be present on a similar engine; no company will go to the expense of manufacturing two completely different engines just because one can be fitted with electric start...
Case in point: Some years ago, I bought a car (Ford Laser) which only had a single wing mirror; soon after, I found a similar vehicle in a scrap yard with dual electric mirrors ; I removed the mirrors, the door wiring & the switch & it all plugged into my cars existing wiring loom; the hardest part of the conversion was removing the door trims to run the wiring...
fast92rs
Old Bridge, NJ
Also just found out that the older 212 motors have a different flywheel taper than the honda clone engines so that flywheel will not work. But if you have the newer hemi 212 I believe that has the same taper as a clone. I am going to get a lighting coil and see if I can add the magnets to the back of my existing flywheel. They are just expoxyed on. They sell a kit for marine applications to add magnets to a flywheel. So I can see if I can remove the magnets from another flywheel or go to the marine parts store and see if they have magnets the right size.
firemanjim
Just kartin' around....
Houston Texas
I'm pretty sure that they need to be purpose made for the application. I don't think you're going to get 12v by adding some magnets. Buy a replacement lighting coil off ebay, then see if it will fit. I'd take my flywheel off first, just to look..... :thumbsup:
fast92rs
Old Bridge, NJ
Took the flywheel off and there is a spot for the coils. When I get a chance I will order the coils and go from there.
machinist@large
West Michigan, 49331
Nope, Uses a Kohler taper.
While I don't know about the CS taper of the Predator engine's, I do know that my my 18 year old Kohler engine in my walk behind lawn mower is recoil start only, with none of mounting points for charging or starting on the block machined. It appears that some times when the option isn't present, it's just not a swap/plug- n- play.....
fast92rs
Old Bridge, NJ
True but I happen to have a machine shop local to me. I'm wondering if they can machine the honda clone flywheel to match the taper of the predator. I haven't looked to see what the difference is but it's worth a shot.
rmm727
Brookville, PA
If you can keep the labor costs down it certainly is worth a shot.:thumbsup:
fast92rs
Old Bridge, NJ
I just ordered on ebay a honda lighting coil and flywheel. I will try the machine shop route first. If it can't be done they I will remove the magnets from the honda flywheel and place them on the predator one.
I think the flywheel needs to balanced with the magnets on. I dont think you can just swap them over.. at least my understanding of these things.
fast92rs
Old Bridge, NJ
So I got the lighting coil mounted. (The easy part). So now comparing the flywheels. From what I can measure the honda flywheel may have a smaller taper than the predator. I called the machine shop, they said bring it by to see what they can do. I got my fingers crossed that they can make it work. If it doesn't work then I found a baja 165 engine that I can cheap and jusr use the parts I need from the predator and reuse it for another project.
