fast92rs
Can a predator 212 be fitted with a alternater from a similar engine? I want to run led lights on my new project and I'd like to have constant power instead of just using a battery alone.
Also just found out that the older 212 motors have a different flywheel taper than the honda clone engines so that flywheel will not work. But if you have the newer hemi 212 I believe that has the same taper as a clone. I am going to get a lighting coil and see if I can add the magnets to the back of my existing flywheel. They are just expoxyed on. They sell a kit for marine applications to add magnets to a flywheel. So I can see if I can remove the magnets from another flywheel or go to the marine parts store and see if they have magnets the right size.
The Honda engines (& all other small engines) don't use an alternator, they use a stator (same concept, slightly different application); the stator setup is attached behind (read inside) the flywheel...
As there are some engines available with all the electric start gear, you wouldn't think the same engine without E/S would be much different, meaning, the space for the hardware, as well as the mounting holes, etc, should be present on a similar engine; no company will go to the expense of manufacturing two completely different engines just because one can be fitted with electric start...
Case in point: Some years ago, I bought a car (Ford Laser) which only had a single wing mirror; soon after, I found a similar vehicle in a scrap yard with dual electric mirrors ; I removed the mirrors, the door wiring & the switch & it all plugged into my cars existing wiring loom; the hardest part of the conversion was removing the door trims to run the wiring...
Nope, Uses a Kohler taper.
True but I happen to have a machine shop local to me. I'm wondering if they can machine the honda clone flywheel to match the taper of the predator. I haven't looked to see what the difference is but it's worth a shot.
