About to throw this crap in the trash
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
So I was given a mower with a 6.5 Briggs engine which will run fine. The problem lies within the priming system. So far I have done everything to it. I started by boiling the carb in lemon juice for 20 mins and blowing all the holes out with carb cleaner. THEN poking each individual passage with a wire (tooth picks don't do anything) and the carb is completely clean. Another thing I noticed is that these carbs look like they're made crappy. It turned all rough and felt a little bit corroded. This has never happened to any other carbs I've cleaned. Today I went and got a complete overhaul kit and changed every possible part in the carb. It doesn't prime for anything. The gasket between the air filter back piece and the carb is a new gasket and it still refused. I'm at the end of the rope here and I'm fed up with this mower.
Also, yes the screws which hold the plastic air filter back piece on to the carb are tight. Spraying some WD40 at the carb entrance shows it bubbling up when I push the primer. And the only sound the primer makes it air hissing.
klicky96
Sandusky, Ohio
Check your fuel. If the primer is only making a hiss noise then you aren't getting any fuel. Make sure your fuel lines are hooked up properly.
Brandon1023
needs an oil change
The bowl will fill up all the way and placing a paper towel soaked in gasoline allows the engine to start up and it will continue to run, The issue is only pre-starting. Why do lawn mowers use a primer system anyway? Why can't there be a nice, simple choke?
klicky96
Sandusky, Ohio
Ahhhhh, hmm, there may be a hole in the bulb itself, or it may not my seated correctly. I once had this problem. The small, O-clip type thing wasn't pushed in all the way with mine and it was pulling in regular air. Your problem may be caused from a clogged intake line going to the bulb itself. I am guess this carb is on top of the tank.
Brandon1023
needs an oil change
Nah this carb looks like a normal one which mounts on to the intake pipe and connects with a line. Its actually below the height of the take, so filling is not an issue. Something I should mention is that there is a small hole in the center of it. It looks ,like it was designed this way, though. Could this be some kind of vent to the bulb doesn't get sucked inward when the engine runs, or it definitely isn't supposed to be there. Will post some pictures when my uncle wakes up and the garage is unoccupied :p
Brandon1023
needs an oil change
Went to the shop today and the guy told me that it was too rough of a surface so I nened to sand it because the lemon juice corroded it. So I sanded it, and it looks really smooth. Went ahead and put everything back together and guess what? It still refuses to prime. The next part to change is the entire carb, and ill throw it in the trash before I go through even more problems.
Brandon1023
needs an oil change
Yep I was told that this moring. Thanks. After hours of sitting here, I think I've narrowed it down to the seal between the plastic primer housing and the carb. I replaced the gasket for the 3rd time now and have tightened both screws to all kinds of torque. No matter how tight and how many gaskets there is in place, it still makes that same pathetic hissing sound.
I also tested the primer housing in a bowl of water. It takes in water and squirts it out just fine. This stupid thing just does not want to make any effort to suck in gas. Yes the hole is clear because i ve probably squirted half a can of carb cleaner through it. A few times already, gas would just drip out the 2 holes and require removal and reattactment of the carb.
Brandon1023
needs an oil change
Nah. Since I see people still reply to this thread, I might as well give you all an update.
After boiling it and discovering a problem, i took the carb to the shop down the street, and my buddy (the mechanic who works there) told me that the side where the cover mounts on is corroded and bumpy. So, as he advised, I took some fine grade sand paper and smoothed it out (perhaps unevenly or not enough even though I sanded it using my kitchen counter as a flat). Still nothing. The holes in the carb got stripped from so much frustrated effort lolol. So I'll take a trip to ace hw and get some matching screws which I can secure with a nut. Yesterday, I went back to the shop and another mechanic gave me a free match of the part I need. He said the piece has a crack in it from over tightening the bolts *insert embarrassed face here*. As expected, the part he gave me didn't work. The only possibilities I can imagine would be to go BACK to the shop and get 2 gaskets since I have read on Googled websites that this has been known to remedy the problem. I guess I'll evenly sand it down again and give it another shot before I'm forced to replace the carb which I may be able to get for free since I'm in the process of gettin hired there XD
