A Noob needs help
Wolth Teef
Arlington, Ks
Hello, this is my first go cart, I have worked on it a bit and had it going good for a couple days but now the clutch doesnt disengage properly. Can anyone help me identify what is on my kart? Any ideas on how to figure out what happened? Thanks in advance.
[/URL][/IMG]
Half-breeder
"Edit" button removed
Needs maintenance. Copper ring may be getting jammed in sheave. The "slide" is probably gunked up.
FabricaTim
Phoenix, AZ
:iagree: I had the same issue. The Drive Pulley(on the engine) has a brass ring that gets stuck with the spring compress(engaged). Check out KartFab on YouTube for "how to clean a torque converter"
Half-breeder
Sorry, when I give short vague answers like that Im usually inline for something that Im bored of looking round at... (today it was wife in the store)
*Yes, I think you should check to see if the copper ring(hopefully you have one) is jamming itself into the sliding sheave's ID (inner diameter).
*If not... then the slide is probably wedging on something in the sheave's slide grooves.
*If thats not it... then check the inner hub, of the sliding sheave, part that touches the weights ID, for any damage/nonfactory grooves.
It possible that it maybe something else... but ive found those to be the top 3 reasons (for me) that the clutch doesnt disengage the belt... is the governor removed? Normally 'this' issue occurs on engines that spin over the factory 3600rpms. Also, a Comet brand TC is made of stronger metal... and 'can' w/stand 5k RPMs better.
Wolth Teef
Arlington, Ks
Thanks for all the suggestions. I will tackle it this weekend. Probably just a maintenance issue. Very happy to know exactly what im dealing with.
