A new project is starting! (And a little question)
BerlanBBM
Germany
Okay, but whats the outermost transmission I can use? Because i calculated and the top speed was 39 kp/h and that without me on it. This is pretty slow... do you think we can take maximum 5:1? Than I will have to buy a clutch for the engine...seems to be necessary.
Thx for your help! Greets :)
As long as you do not have large wheels (anything larger than 13") you should be OK on 5:1. You will be borderline though, and your clutch may wear faster than if you were geared lower. Your torque will also be less.
BerlanBBM
Germany
Okay. I´ll never buy me larger wheels then 13" I`m looking for vtires with little nobbs for a little crosstour :) This week we probably get the chassis so I rise when its on me.
Greets!:cheers2:
anderkart
Surprise Arizona USA
You could find a clutch for sale in Germany at this search link:--> http://www.google.com/search?source...1T4GZAZ_enUS369US369&q=Go+kart+parts++Germany
6:1 gearing is a good suggestion, especially if you use one of the lower-cost/lower-quality, centrifugal clutch brands or models. But If you buy one of the (higher-quality) racing clutch models, your clutch could withstand gearing your kart as low as a 4:1 ratio, with 11" rear tires. (or possibly around 5:1 with 13" tires)
But when using these gear ratios for higher top speeds, you'll want to immediately get the kart up to a fast enough speed so the clutch is no longer slipping. This means you'll need to only ride the kart in larger areas without any steep hills (or rough terrain/or any other situations ) that would require the clutch to be constantly slipping.
When you start riding the kart, you'll be able to feel/hear the clutch slipping when you take off from a stop. Then once the engine reaches a certain/higher-RPM, you'll hear/feel the clutch fully engage/lock-in. (at that point the clutch doesnt have any slippage/friction)
So when gearing a kart for higher top speeds, you'll simply need to limit the amount of time the clutch is slipping, because thats the only time the clutch is building up heat from friction, and this heat will eventually damage any clutch. And gearing for higher top speeds, compounds this problem...
