utahoutdoors
So when making the A-Frame I plan on welding a 2.5" long
bushing to the A-Frames. These will be 1" OD, 5/8 ID which will go into welded 2.5" (ID) spindle bracket. Then a 5/8 bolt will
go into with lock nuts on the end.
So the questions to ask.
1. Is there a available bearing set for these spindle brackets
for a-Frames or do folks use bushing.
2. Should I use say 2 or 2.25" and some nylon spacers and each
side.
Any advise will be appreciated.
side.
