a couple carb questions. nice and simple
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
Ok so I'm fixing a mower for a friend. After fixing his mistake of a big cap in the coil, I moved on to starting it up. After wondering why it wouldn't work even with a spark and starting fluid, I realized there was nothing connecting the butterfly to the governor linkage. I'm guessing I need some kind of lever. I will upload a picture of that. Shortly.
On the other hand, I know the carb needs a cleaning so I'm wondering if its okay to boil a tecumseh carb in lemon juice even though it has plastic inlets/outlets as well as a rubber primer bulb. Will it melt? Thanks.
Brandon1023
needs an oil change
Yea I decided to just blow all the jets/passages out with carb cleaner. The carb wasn't in that bad of shape. I just don't understand where the lever which ultimately pushes the throttle open went.. He said he doesn't know anything about it and he hasn't used it in years. Got it running earlier, but obviously it ran poorly without a proper throttle. I'll check with the repair/rental shop down the street, tomorrow.
Off topic: can someone explain how vertical shaft engines are lubricated or give me a link? I have looked and can't find much.
Brandon1023
needs an oil change
I happened to get lucky with Google Images, for once, and found this picture. The metal rod the arrow is pointing to is the part that is missing. Can anyone tell me what this piece is called? Because there seems to be no parts diagrams whatsoever for this engine.
Jake.B
California-USA
Look on you-tube of people converting verticals to side shafts, lots of info in the oil dippers. I have a Tecumseh lawn mower, there are a few different holes a rod goes to on the throttle butterfly. The way mine works is when you start it the governor pulls the throttle, the largest hole opens it to WOT and the others to different RPM. You can play around with it until the correct hole is determined.
Do you have the lever/rod? check the different holes for wear signs this may help you determine the correct hole.
Edit: posted before me, check a parts website for the lever.
Jake.B
California-USA
Just checked out my mower, same carburetor as the one above my rod is in the same hole your arrow points to. I would find your model # and search some websites.
