9hp carburator butterfly
masterbusa2
Okay so when I got this motor it starts first try, but ther outer butterfly isnt hooked up to anything, but the inner is, so my question is how and what do I hook up hte outer butterfly to, and what do I hook my throttle cable to my go cart too, and how would I set the idle I know its a screw but dont know which one xD
masterbusa2
here they are
pics of it
masterbusa2
like the inner butterfly inside the carb is connected to the one wiht hte long rod going to middle of motor guess the governer? but the outer butterfly the one you can see is not connected to anything I have to move it with my finger, idk if that was choke or throttle or what, but where do I connect throttle cable, and where does the outterbutterfly connect to
masterbusa2
okay now i understand how to hook up the cable, I see where it is suppose to mount then screw go in it I understand, but when i pull throttle shouldnt the inner butterfly close? or should it open? because sitting here it is forced open teh spring it pulilng it open, when I pull the throttle it moves it maybe a 1/8th an inch, hardly noticable, shouldnt it move it more? does it have something to do with that long pole and other spring that runs beside the throttle? im bad with directions but hopefuly your that smart xD
Edit: the first pic shows the pole im reffering too, it hardly moves at all, shouldnt it open and close the butterfly alot?
Nodroz
Belgium (Europe)
The "door" that's connected with the butterfly (the ony you can see on the first pic) should open completely if you fully press the throttle and it should ALMOST close when you release throttle. There must be a little hole to let the engine idle.
masterbusa2
its open completelly, like a spring is forcing it to stay open completely I think someone may have hooked it up wrong
Nodroz
Belgium (Europe)
Wait a second...
If you press the throttle, the "door" (Guys please help me with the correct name) will close? If you loose the throttle, it will open?
It should be the other way around.
Don't forget you also have your choke door.
masterbusa2
ya the choke door doesnt work at all its not connected to anythign but yes it is backwards so do i jsutmoev around all teh spring when i do i cna bend springs and it works liek it should liek I moved htem all around then stretched one and now it works the way it should, now about the choke door which way should it stay and how would I hook up a control to it, its hte first door the one with the black knob on pic one
Nodroz
Belgium (Europe)
Look at the picture attached. This is what you need to use to get your choke working. I guess you can easily get this part at any engine shop who sells these engines.
Click
The choke is operated manually. When you start the engine cold, you move the choke to the on position (the door should be closed). When the engine is warm, you then move the choke back
masterbusa2
ya liek right now its loose and I cant get to it with the manifold instaled, so what elver where u gunna psot a pic of nodroz?
Nodroz
Belgium (Europe)
Oop, sorry. Seems like something went wrong when adding the picture. I updated my post with a link.
Btw, when I read our posts back, I see a little misunderstoodment happened. I was talking about the throttle, but you were talking about the choke. I hope it's all clear now? (Throttle working perfectly, choke needs a lever?)
masterbusa2
yuhp:D
and yup
thats all the throttle and choke issues fixed :D
wait one more thing so thsi engine always starts firt time easy so i leave choke door to open when running?
