freshness
I bought a new 94ss dyno cam I need some help getting the motor to run smoothly with the more aggressive cam has anybody had any experience using this cam any help would be great
Please describe your problem. I'm assuming you put it on a Briggs 5 hp flathead. The cam would not be the source of an engine running rough. Look up the cam card and:
1) make sure your valve lash is set to what it specifies on the cam card
2) make sure timing is set to what it specifies on the cam card
3) high flow intake and exhaust?
4) jetted correctly?
5) dot on cam lines up with dot on crank?
what degree timing key did you use to advance the flywheel
how much bigger did you re-jet the main carb jet
I will order some 20lb spring then too
the other guy I know has an aftermarket cam and he used a 6 degree key
not sure what you mean by the air intake?
I need to get an air filter cause this motor came off of a snowblower
Note to BOB...
I think you are talking about your Predator and he is doing A Briggs Flathead.
Not that your Totally out of line, just there are some drastic differences.
