900cc NINJA buggy build. HELP!!
Grind hard garage
Clio Michigan
I’m putting my zx9r engine on a buggy build
I need help and advice with the wire harness
1. Do I need the complete engine harness from the bike or can I just use bits a pieces.
2. if I dont need the complete harness, what are the key parts that I Need to use?
I have all areas of the build covered I’m just lost with what I’ll need as far as wiring because I’ve read other threads where people ditch most of the harness and I’m wanting to do the same so I don’t have a clutter mess.
Joe-405
Enjoying New Projects
U.S.A.
Ummmm how well are you at wiring before I answer ! I did mine with a zx12r and it was last years build off winner. If you wanna go see what I did.
if your not half way decent at wiring don’t do it ! I build efi systems and wire cars on the side and it was still not easy for me.
chimmike
First thing you need to know is exactly which sensors are needed for the PCM to operate the engine. Once you know necessary versus unnecessary you can eliminate from there.
