this engine came off of a generator and I am worried about the shaft - will it work?
K KennyB New member Messages 9 Reaction score 0 Nov 26, 2010 #1 this engine came off of a generator and I am worried about the shaft - will it work? Attachments Pic697.jpg 35.2 KB · Views: 1 Pic699.jpg 47.2 KB · Views: 3 Pic698.jpg 61.5 KB · Views: 1
Russ2251 AZUSA:Powered by LAWN-BOY Messages 6,622 Reaction score 47 Location Huntington Station, Long Island, NY Nov 26, 2010 #2 Only by reworking shaft dimensions. We avoid them. Best to put generator back together, sell it...and get the correct engine.
K KennyB New member Messages 9 Reaction score 0 Nov 26, 2010 #3 unforutnnately the generator did not come with the project just the engine I guess this project just came to a halt
K KennyB New member Messages 9 Reaction score 0 Nov 26, 2010 #4 I have a 5hp off of a pressure washer I will look into it tommorrow just dont know if it will be big enough to turn atv tires
Doc Sprocket ********* Messages 15,677 Reaction score 153 Location Ontario, Canada Nov 26, 2010 #5 You're not out of options, yet. You could get the shaft machined to an appropriate dimension, or purchase the correct crankshaft.
Bluethunder3320 New member Messages 5,677 Reaction score 39 Nov 26, 2010 #6 wow, i just finished rebuilding my 8hp briggs today. search on ebay "8hp briggs crankshaft" you could get a new one on their website but it may be $$$$$ the shaft on these youre looking for is a 1" bore with keyway.
K KennyB New member Messages 9 Reaction score 0 Nov 28, 2010 #7 ok I just got the pump off the 5 hp where is the best place to buy a clutch from?
Bluethunder3320 New member Messages 5,677 Reaction score 39 Nov 28, 2010 #8 ebay it. look for a maxtorque clutch and then whatever shaft diameter yours is. probably 3/4" though. i could be wrong.
redsox985 Active member Messages 4,092 Reaction score 12 Location PA Nov 28, 2010 #9 Before you but a clutch, does the 5hp have a keyway and is not tapered?
Bluethunder3320 New member Messages 5,677 Reaction score 39 Nov 28, 2010 #10 Yeah thats good to know... Post a pic if ur not sure.
K KennyB New member Messages 9 Reaction score 0 Nov 29, 2010 #11 yes it has a keyway and it is not tapered like the pics
