tundrabeagle is on the right track... I foolishly took out most of the threads on my 8hp when I ported it. I tried JB Weld, but the heat killed that. I ended up getting a bolt-on muffler flange, cutting it in half, bolting it to the block (should be holes on either side of the port), and putting a piece of 1-inch metal conduit on for a header pipe. OK, I hammered the conduit pipe onto the flange before I bolted it on, but....it works like a champ, I just need some sort of muffler for my ears now.
If yours doesn't have bolt-holes on either side of the port, I'd look into drilling and tapping some, unless yours is wildly different from other Briggs 8hp's I've seen there's plenty of meat there.
The other alternative would be to tap oversized threads into the block and use either a thread adapter or a completely different muffler or pipe.
