8hp briggs exhaust pipe
manco36
Hey I have an 8hp briggs and the threads on the engine where the exhaust screws in are all messed up. Anyone have any ideas of how to get it back on? I have debated on tack welding it on three or four sides.
tundrabeagle3
Ca
you could tap it , does the 8 hp briggs have any exhaust mounting holes? usually there is one on each side of the exhaust. if there are mounting holes than you could weld up a header just use a very large washer as an header flange. cut it to make it fit, drill holes for the bolts, then weld the washer to your exhaust pipe, make an exhaust gasket and mount it on with the right size bolts .
manco36
Wow, I like that idea man! My kart is not at my house right now so I can't check for the mounting holes but I think I recall there being a hole on both sides. (Similar to carb mounting holes). What would be a good material to construct an exhaust gasket?
I'm not sure what size the threads are..
Would love to tap it to get it working correctly. Never tapped anything before though. I'll have to go read up on it.
Thanks for the help.
jamyers
Buffalo Gap, TX
tundrabeagle is on the right track... I foolishly took out most of the threads on my 8hp when I ported it. I tried JB Weld, but the heat killed that. I ended up getting a bolt-on muffler flange, cutting it in half, bolting it to the block (should be holes on either side of the port), and putting a piece of 1-inch metal conduit on for a header pipe. OK, I hammered the conduit pipe onto the flange before I bolted it on, but....it works like a champ, I just need some sort of muffler for my ears now.
If yours doesn't have bolt-holes on either side of the port, I'd look into drilling and tapping some, unless yours is wildly different from other Briggs 8hp's I've seen there's plenty of meat there.
The other alternative would be to tap oversized threads into the block and use either a thread adapter or a completely different muffler or pipe.
manco36
The person who owned it before me had already put a thread adapter on the exhaust pipe. So I'm unsure if this is an aftermarket exhaust or what. But the adapter made the end smaller so I think they just took a hammer and smacked it in as far as they could before they sold it to me. Which would explain why it slowly got loose and just fell off one day while riding. I've never tapped anything before. Is it difficult? I'll have to read and watch some videos to educate myself I suppose
DS13
Annoying the Neighbors!!!
Elysburg, PA
Not entirely to hard. Just make sure ya get the same thread size, and while you are in the process always go half turn in the direction of the thread and then quarter turn back to knock off the bur it creates.
tundrabeagle3
Ca
If you put a heavy header with a muffler in the new threaded exhaust hole, it will wobble loose eventually. I had it happened to me when I had my 5 hp briggs i would turn it in all the way and after a long ride it would come loose. The exhuast would always bob up and down when it idled. I did made a little header with a washer and bolted it on to the muffler mounting holes. it fixed the problem with the header bobbing up and down. this method also flows better than having some threaded pipe screwed all the way in.
jamyers
Buffalo Gap, TX
Good point, tundra beagle - anything much longer or heavier than stock needs a support of some sort, I took some 1/2" conduit and made mine - don't have to be fancy!
manco36
Yah. I think I'll give the washer idea a shot. Got the stuff to do it already. Headed to a friends to get it welded in the next few days. Thanks for the help
manco36
When you say "exhaust gasket" your referring to the washer welded to the end of the exhaust pipe correct? That's all I should need right. Nothing else between the washer and the motor?
jamyers
Buffalo Gap, TX
You'll need a gasket between the washer/flange and the engine, or it'll leak. Oughta be able to pick one up local for a buck or two...
manco36
Well I got a chance to get over and do some work on some karts today. (Good times).
Looks like the two muffler holes are also stripped. I suppose my wanting to stay away from using the tap set is not gonna happen.
Also I noticed theres not very much room between the edge of where the carb pipe (guess thats what its called) goes in to the motor and where the two exhaust holes are. Might need to drill right at the edge of the washer to get it to fit on there.
Trying to post a pic for you guys to check out. Can't seem to get it to upload.
Thanks
manco36
Correction: Edge of the Carb pipe and "one" of the exhaust holes. The right one
