Gottaknowjoe
- Messages
- 20
- Reaction score
- 27
Hey, friends, the long version with more info is below. I'm questioning how to properly tension the chain and belt to jack shaft using 530 chain and what product to use.
I've been working on this project that is working on me.... The all aluminum Dumping bed Club Car. It WAS power by an fe350 kawasaki engine that I rebuilt, but disappointed in the power and sound. ...sound mostly I decided the 350 would better power a desk fan..
A buddy gifted me a low mile vn800 Vulcan that was torn apart.. an abandoned bobber project. The wiring was a task and made me 2nd guess my friends intentions giving this bike up so fast..but I overcame and she runs like a beast.
My Question, no.. QUESTIONS LIST adds 2 line items every time I'm able to
one off....
The org clubcar engine was bolted to a steel pan. The pan was bolted to the transaxle the engine to the pan. Photos added. . The transaxle engine and pan have this give, for obvious reasons. So I incorporated the bikes mount Design and carts design to keep it as close to the org setup as possible.
I'm installing 56 hp over the 11hp that was burdened to push the cart. Removing the dump bed cut a 3rd of the weigh...but now im dealing with a hurdle. Transferring counter clockwise power fron the 800 power plant to a clockwise cart transaxle. I guess I forgot to mention I started this journey with one of the only clockwise output engines on the market. And the transaxle stays, I'm not losing reverse. It's not productive to tell the wife SHE IS THE REVERSE GEAR.
I'm not a heavy footed guy (Bull-beeep!) My plan is to use responsibility, I'm really after that nice vtwin sound with the reliability of the Japanese engine, not top speeds, or a BUSA would be going in.
The bike and cart both had soild mounts in rear and dampening device(s)/motor mounts in the front. I kept this the same, the Engine to transaxle is still like factory, design....the rotation torque on transaxle and the engine moves with it as one. . I thought about using a coilover shock as a front mount but desided to just use a normal car single stud frame mounted engine mount.
Now to the Jackshaft. My chain will not be long the belt will be about the same. I can not slide the engine to adjust tension since the transaxle and engine are one solid unit i cant adjust shaft since the chain is on one end and belt the other... there is no way i could tensionwith shaft and keep it all squared.
Can you adjust chain with a tensioner if so where can I find one . The 2 shouldn't be affected much by the suspension where I plan to mount it . Thank you for any help or ideas to pull me out of this mud I seem to be stuck in.
Writing about any project or subject sparks ideas for me......so it's one reason for the above-mentioned ramblings sorry to bore you with them.
. Cheers Joe...
I can't leave fixed alone Because it's just boring.
Plan is to place Jack shaft on cross bar that's parallel and behind the axle
. Cheers Joe...
and I am still looking.. the 530 chain the bike came with is overkill for my needs. This will be the 1st Building of a jackshaft in my shop as well so I'm just not familiar with how the stuff is marketed and sold. I'm still not 100% clear on the exact location the shaft will live at this point..
and all the bikes I ride have the output on the portside/drivers or left side and turn in the same direction as a time machine clock (counterclockwise) This is the only reason for the jackshaft. But trust me every time someone questions or asks about this I panic inside a little thinking I missed something or have it turned around. lol
