79cc Plastic Cam Gear!
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Well I just cam across this at AGK. On a 79cc Predator the Cam gear is plastic.
We usually gut the Gov because of its plastic gear that cannot handle the RPMs. I guess the gear reduction between the crank gear and the Cam gear make it ok?
I just found it interesting. What are y'alls opinions?
plastic =/= plastic..
plastic cam gears (as seen on more than just the 79cc predator and some briggs) are most likely fiberglass reinforced ABS
whereas the governor isn't reinforced..
you can even kindof tell by just looking at the pic you posted..
see how the governor is all shiny and smooth whereas the camgear is rough and dull?
Anyways, sometimes reinforced plastic gears can outlive sintered metal gears.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Wow there is that carbon fibre/ plastic/fiberglass thing again! really cool stuff!
hehe.. yeah well, what can I say *shrugs*
fiberglass is literally everywhere;
if you open your tool drawer I'm sure you'll find several powertools with fiberglass reinforced plastic parts (cases as well as internals)
If you go to the kitchen I bet you'll have that stuff in nearly every electric device as well.
heck, even your office chair will likely be made (in parts) of that stuff.
Anyways...
if you carefully look around, you'll likely be able to find it in every single room of your house.
Yes. GRP(glass reinforced plastics) are everywhere nowadays. Alot of car/motorcycle/truck parts are all plastic.
Gears and in this case... Cam/gears are typically made of glass reinforced nylon. Acetal is also a contender as is has a good oil/gasoline/chemical resistance, aswell as good mechanical/lubricant properties.
Nylon has a higher flexural modulus than ABS... Equally much more with filler.
Staff Murderator
Nothing new. Other similar examples abound, not to mention the relatively ancient use of plastic for the governor gear probably pioneered by Briggs or Tecumseh. I don't know about use in critical automotive parts but Nissan and others have used "plastic" intake manifolds for years now.
