79 fl250
mike75925
thinker and tinkerer
Alto, tx
it's a tapered shaft, and about the only way without destroying the clutch is the tool. when i had to replace my seals, i took mine to a shop i do a lot of business with, they did it free.
mxstud1804
is there a holding pin? It almost seems like you have to pull the motor to get it off, thanks for all the help so far
mike75925
Alto, tx
just the bolt and the pressure made from the tapers meeting. bikebandit.com, (under oem parts) honda, 1979, fl250, look at the fiche it will show you what all goes where.
