ghost civic
I got my trike built from a 70cc kids atv
It was running good
I had to remove the carb to adjust the float, and at the same time I changed the oil. The engine had a 1/8'' layer of caked stuff at the bottom after draining the oil. Put new oil in and figured it would be fine.
very shortly after that, it started to die any time you gave it throttle. It would idle and always start back up fine but got so that it couldn't even move.
The carb on it was old, and I figured a new one would solve the issue. Put a new carb on today, it started right up but then died when I gave it throttle. I checked the valve lash...both were tight but since it was able to start and idle I figure they couldn't have been too tight. I gave them both a bit of play but the bike still would not move. I adjusted the mixture screw on the carb and off it went...but only for 100' or so, then started acting up again. No adjustments to the carb made it any better, it actually got so it would start, idle for 10 seconds or so and then die.
I went to check the valves again and noticed a hole in the engine which would lead to the timing chain cavity.
I am wondering, would a hole there prevent oil from being pushed up to the valve train? I don't honestly know what moves the oil to the valves/rockers...and I'm wondering if either the hole is preventing oil from flowing there, or if that caked up stuff I found when changing the oil ended up blocking an oil passage.
The picture shows where the hole was, I just put high heat stick weld over it.
It was running good
