6hp Robin Engine
cmbone
WA
Hi, anyone running Subaru Robin engines, are they better then clones? This one has the cool 2to1 reduction & wet clutch.
Is the honda wet clutch better? :popcorn:
r97
Measure twice cut once
Massachusetts, USA
Better than clones? Clones don't got crap on a good robin subaru! Check out all the specs, and features of the "EX" lineup on their website, you can tell they put some good thought into it, NOT just ripped off a Honda;
http://www.robinamerica.com/series.aspx?sid=7
I have no clue about the wet clutch, but it's most likely Honda or Subaru, so it should be excellent ether way (do they even clone those?).
If you are willing to give up the wet clutch look on ebay, you can get the 6hp for $220, 9hp for $275(1" shaft), or 7hp for $325(7hp & 9hp have more performance parts available).
jamyers
Buffalo Gap, TX
The Robin engines are very well-built, with cast-iron bores, dual bearings, great designing, etc. The only drawback I've seen with them is a lack of aftermarket internal performance parts like connecting rods, cams, etc.
I also have no clue about a wet clutch, I didn't know anybody made one for these smaller engines. Got a picture of that side of the engine?
r97
Massachusetts, USA
Yeah a lot fewer aftermarket stuff is available, but the plus side is that the parts are strong enough to take a fair bit more abuse than usual. Look into the Robin KX21 engine, i believe it is basically an EX21 with exhaust, timing advance, air filter, and just a few other things. Maybe a billet flywheel too?
Also the EX27 has a fair number of pars available, but that engine is pretty big.
cmbone
WA
I Got a picture of that side
Thanks Guys!
Hears the Robin, The honda G-box looks way different, maybe smaller.:popcorn:
