6 HP tecumseh PROBLEMS?
bikerboy1000
Want start, got it from a buddy, i cleaned carb, and changed oil, new plug in it.. It ran fine for one day, the next day, it want start at all.. Spraying fuel out carb top (a mist) right where throttle cable hooks up.. And when i pull it to start it, sometimes it will yank back on me? I think maybe timing? I put a lil gas in cyclinder, still want start? Any help would be great?
Bluethunder3320
The spray of fuel is just from when you choke it it sucks exessive gas into the intake and some just gets pushed out. Try un flooding it and if it still kicks back check the flywheel key. The kickback could be from a flooded engine. Does it pop or backfire? Any spark?
bikerboy1000
It come on the go kart when he bought it new... Its not flooding, gettin a good spark.. Ill check the key next day i get off.. Thanks
Russ2251
AZUSA:Powered by LAWN-BOY
What's special about a woodchipper
Woodchippers use a lighter (not lightened) flywheel.
Lighter flywheel has a lack of inertia.
This has come up before.
All the 'experts' agreed that it was a sheared key.
I (not being an expert) disagreed.
Upon disassembly, it was discovered that key had NOT sheared. Engine was indeed behaving normally.
Thanks, Russ, for the explanation. Please note that I do not claim to be an expert, nor did I insist that it was the key, I simply suggested an inspection of same.
slideways
Check the valve lash.... before you to go the trouble of checking the flywheel key. Very rare to shear a key on a go kart. Unlike a push mower or a chipper or something where the motor is working directly against the object being worked.
The lash is one of the only things that can lost adjustment during riding and cause this kick back and backfire like you describe. Ask if you don't know how to do this.
r97
Measure twice cut once
Massachusetts, USA
a wood chipper prob has a lightened fly wheel because its spinning a huge metal wheel with blades which acts as a flywheel, if it had a normal fly wheel the "chipper" wheel would just be extra weight to move, but if you lighten the fly wheel the "chipping wheel" adds extra inertia to compensate for the lost inertia of a lightened fly wheel.
EDIT: beat me to it!
