6.5hp Honda Clone getting outrun by a 2.8hp! HELP!!!
Clayton
Saskatchewan, Canada
Okay, I just took my mini-bike with my 6.5hp clone out for a run tonight with my sister on her db30 with a 2.8hp (the gov is adjusted). Anyway, she blew past me with the clone pinned! :censored: :mad2:
I noticed that it started perfect, and when I would start out I would just fly, but once I had the twist throttle maxed out it would give er' but then would bog down to a little bit slower speed seconds after. :confused:
Personally I think it isn't getting enough fuel, but I am wondering if anyone else has had this trouble, and wanna know what they did?
My bike is a Baja Heat (it has a different clone on it because the original owner sold it, and I just bought the frame) but I am still running the jackshft that was running on the original engine. Or is this just how a stock baja heat runs with that jackshaft? :worried2: :furious2:
Thanks for any help :cheers2: :auto:
anderkart
Surprise Arizona USA
You might have a problem, but your probably just feeling the way your governor suddenly closes your carburetor as the engine reaches around 3600rpm. (its normal to feel that when the governor kicks in)
If you want a higher top speed you'll need to re-gear it or remove your governor, or both.
Bluethunder3320
is it possible to move the governor arm back a little?
anyways, i had this happen on my mini bike i used to have working, it would go REV then low then REV then low then REV then low when i pushed it past the stock 3600RPM.
regear it. this rev and die thing wouldnt happen if there was a larger load on the engine.
can a almost stock DB really hit 40????? i thought they went 15mph MAX.
Clayton
they go 20mph max, but I have a homemade header, I figured out a way to adjust the needle on the carb so it gets alot more fuel (than the stock setting), and I did some work on the govenor arm. I used to have a hardwire linkage straight to the carb but since my sister drives it I wanted it to be safer. Guess I have to re-gear it or just by-pass the govenor.
karl
North east Ohio
So she was doing around 22mph and you were doing about 20mph. I highly doubt she was doing 40mph, that is unreal. Use the speed calculator and see how many rmps it would take to get that mini bike moving at 40mph. Its 2.8hp and with a custom exhaust and running to rich you might get 2.8hp.
karl
North east Ohio
That is something I wanna see what are the sprocket sizes and how tall are the tires on that 2.8hp minibike?
Clayton
the wheels and tires together are like 12'' tall and the sprocket on the clutch is a 11 tooth, and the rear sprocket is a 70 tooth. It took a lot of time, but it goes good, and sounds like a weed wacker on steroids.
Clayton
I used to have a hardwire linkage straight to the carb, and it probly went 35ish but my sister rides it mostly now, and I want it to be safer for her.
karl
North east Ohio
So that 2.8 hp mini bike is reving 7000rpm to hit 40mph. I highly doubt that that story is a load of crap :poop::poop:
r_chez_08
Should be in the shop...
Cornwall, UK
Oh wow, asking for rod failure.
Yeah you could get a 2.8 going 40, on a mile long road and with higher gearing!i highly doubt you were doing 7000 rpm with no other mods.
What did you measure the speed with?
Rob
Clayton
No it runs 30mph now with adjusted gov, header and a carb kit. It used to go just under 35mph (33.7mph) with a hardwire linkage and bypassed gov. I used a GPS. I guess I will have to get a video on a helmet cam, and show the gps reading while riding.
redsox985
PA
What all have you done to each motor? Tweaked gov is different from no gov.
r_chez_08
Cornwall, UK
According th the speed calc. You were revving about 5800rpm. If your gps reading is correct, then that 2.8 must have stiff valve springs! Still asking for a hole in the block though ;)
Rob
karl
North east Ohio
the speed calculator dosent calculate wind, drag, weight or any thing. Just if your motor made it to a certain rmp
Clayton
I know. And I know I will probly blow it up, but I have a 3hp briggs ready to drop in it, and another that has to be rebuilt, so I am not worried. I'll list the mods to my 2.8hp:
1. tweaked governrer.
2. drilled main jet, carb needle opened to run rich.
3. straight pipe/header (whatever you want to call it).
4. modified stock air intake.
I am 150lbs, and my sister is like 100lbs if that.
