6.5 Tecumseh no spark
Avery
My son just bought a Carter kart , it has no spark. We pulled the coil, cleaned it adjusted it. It has 2 kill switches which seem to work, I have continuity on both of them. I even pulled a coil off another 6.0 hp Tecumseh that's froze and nothing. What am I missing? I've been a car guy for 35 years, never played with small engines tho. Any help is appreciated!!
Avery
Ok, so if I leave all wires off except for the coil wire it will fire? If it doesn't it then it's a bad coil.
Two wires on the coil. One to spark plug. The other when grounded will kill the engine. It should be an open curcuit to run. If you have a constant contact switch it will be backwards. Off is on and on is really off.
