6.5 Techumseh Help
Paulzbike
I have a 6.5hp motor with very little use. It has been very dependable and always started right up with (3) presses of the primer bulb and one pull of the starter cord.
I opened the motor side cover and removed the govenor gear, closed the motor up and attached the linkage spring directly to the carb and filled it back up with oil.
Now it will not start on its own. I need to pry open the butterfly and spray some starting fluid in it. to get it going.
It will run really fast as long as I keep the throttle open. it seems to be spraying gas out on the air filter from the carb. I have adjusted the idle air in a little but it still wont start on its own acord. If I let the butterfly close on its own (to hopefully idle) it dies.
I lowered the fuel bowl to see if there was anything funny going on in there, everything looked fine. When I put the bowl back on, it now will not squirt fuel when the promer bulb is pressed.
I am reletevly mechanically inclined, but this has me stumpped.
Ive tried some small engine repair shops and lawn mower shops but as soon as I say go cart they shut down and will not touch it.
Any help would be greatfully appriciated.
Paul
