6.5 hf shuts off when running
redsox985
PA
Oh, your watching THAT Top Gear. I hate the british version. The American makes me fall over in laughter.
If you like actual car analysis and watch it for the vehicular value, the British one is much better. If you want some car info and a good laugh as well as entertainment, the American one is for you.
South Kart3377
Kart designer
Va
What is the point of this?
MY Briggs plain out would not start till I began using lucas, sta-bil adds octane about 25
okay now it will not even run, also the nut holding the carb on is 3/8th but it will not fit a 3/8 socket or open wrench so i am lost at what to do
THe anwser:
Elaborate on "not run"
it wont start at all now? Make sure you put everything back the same..
check and recheck...
Id dump any previous gas you had in your fuel tank prior and put some fresh gas in it. You may have had some water in the old gas prior to you having issues.
Save some of the old gas in a glass jar if ya want.. if it had water in it you will see bubbles at the bottom of the glass......if it looks like solid gasoline with no bubbles or dirt at the bottom of the glass jar then you are good. Don't put any of that stabilizer crap in the gas either. As to the other posters comment about the fuel mixture, get the cart running again before you start experimenting with fuel, additives, meth, etc.
The "stabilizer crap" adds octane about 25.
well it will sound like it is going to turn over but just stop before it fires so i am going to get a new spark plug today and see if that will fix it
That should help, I hade to do that also.
Well I don't know. I just saw on top gear when the guy tested his plane he said if there was any water it would show as a separate layer on top.
Then hes an idiot:toetap05:
:iagree:
Prob because they're British :D
**** "British"
**** "British"
there is an American one??
YES!!!!!
History Channel, Sundays at 10 EST. Better humor.
I love it.
Sweet thanks I'll go check that out.
Good.
I agree!!!
redsox985
PA
^^^ What was the point of this? And Sta-bil is a stabilizer that helps gas keep when it's going to sit for a while and would otherwise get stale and varnish.
South Kart3377
Kart designer
Va
A mini cup racer said " It will be about like running Methonal, should give you 25 octane more, Walker" Alen Mason Mini-Cup #53
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Do you even know what the octane level indicates??? Octane indicates the resistance to detonation, as in, the temperature at which the fuel/air mixture ignites. Contrary to popular belief, higher octane fuel WILL NOT make your engine faster or more powerful and IS NOT cleaner than regular ol' 87 octane.
South Kart3377
Kart designer
Va
I know but, it gets higher hp:cc , and runs a little smoother.
redsox985
PA
Like said above, higher octane gas is only good for high compression engines to prevent knocking. In high compression engines, the compression alone can compress the fuel air mix to the point where the mix detonates prior to the spark firing causing the internals to knock. An average kart engine is probably not going to have a high enough compression ratio to warrant higher octane gas, or even octane booster. Stabilizer makes sense if you don't kart often, but not octane booster.
It does not improve the power output of your engine (hp:cc in your words). It's not worth the $$$.
South Kart3377
Kart designer
Va
But nice if you don't have GAS.
Okay, let's back this up a notch or two. It was stated above that this StaBil/Lucas swampwater goo mix was a CRITICAL step in carb cleaning. I still disagree, and fail to understand why it was stated as such.
With regards to this, "it's nice if you don't have fuel"-
I know gas is getting more expensive all the time, and most of North America is over $4.50/gal, buy why in Dog's name would you burn that mojo mix you talk about? I know full good and well it will work out to be a ot more per gallon!?!?!
THIMK!
And once more for the masses-
Raising the octane rating does jack diddley squat on a low compression engine. Write it down, it'll be on the exam.
Because a higher octane rating means a higher resistance to preignition, aka detonation. As a higher compression engine comes up on the compression stroke, more volatile (less stable) fuel will ignite even before the spark because of the high compression and heat. This can not only cause a loss of performance, it can physically break your engine. Fuel with a higher octane rating is more stable, and resists (sparkless) detonation.
redsox985
PA
I only put some stabilizer in my tank since I'm still in the process of getting a new driven spring and buttons, and well, the kart's sitting for a while.
devino246
Lynchburg, VA
Interesting thing is, Ive run my modded clone for no more than an hour since I modded it last spring and maybe added gas to it twice and yet it still starts like 2nd pull..
