i would drain the harbor freight crap oil anyways, you know it may be fish oil? LOL. get some good oil. even stop&shop oil will be much better.
spark plug may need to be cleaned after break-in. a wire brush works fine. if you dont have this, sandpaper can even work. and a toothpick.
if it STILL has the problem, pop off the little cap on the idle speed screw, and tighten it just a little each time with a phillips head screwdriver until it is right.
hopefully after trying all these things it will be fixed. i heard someone on the PBP forum recently have a similar problem because the fuel-shutoff was not allowing in enough gas.
