From engine to rear shaft is 12 to 26
Then from rear shaft to wheel is 12 to 60
So 12-12-12-60?
If you buy a 10 tooth clutch, you can bypass the jackshaft. If you can't find a 10 tooth clutch, change the 26 tooth sprocket for a 14 or 15 tooth. I think? Someone double check me.
15 tooth would get you closest to 6:1 So there, nyah nyah.
