Pellethuntr2
Machinist
Question for all you experienced guys.. I have a 7hp Briggs with one of those bolt on 6:1 gear reductions.. My question does the gear reducer take the place of using a large rear sprocket for more low end torque? I plan on using a standard 12 tooth clutch, so does that mean I should get a 12 tooth rear sprocket to keep the 6:1 ratio? The rear tire on my bike is 26 inches and a 6:1 ratio seems to be a good mix of speed and low end.. thanks for any help
