Valve float DOES NOT MATTER on a flathead. In out application, the worst that will happen is it will knock the carbon loose from the head. Most racing cams for flatheads are actually designed to float the valve (thus providing more lift on a cam that still passes tech for maximum lift).
Now if you're running an ohv, valve float is a different story.
