5hp Briggs cfm?
Jimmy_B
Just the straight math with stock bore and stroke.....
Area of bore = 3.1416 × radius squared
Bore x stroke = cubic inches
Stock bore = 2.5625, so radius = 2.5625/2 = 1.281
Area of stock bore = 1.281 x 1.281 x 3.1416 = 5.155 square inches
5.155 square inches x 2.4375 (stock stroke) = 12.566 cubic inches
At wide open (3600 rpm with governor) and knowing the charge is drawn only every other revolution (1800 rpm) we multiply 12.566 cubic inches by 1800 cycles per minute yields 22,618.8 cubic inches/minute. 1 cubic foot = 1,728 cubic inches.
22,618.8/1,728 = 13.09 cubic feet per minute
These are static numbers and don't account for the many efficiencies/deficiencies involved with air flow.
How did I do?
Best I can do. I have built a lot of these before, but never had one on a flow bench.
falcon52
Depends on where ARCA race schedule is
O well thank you sir! I just realized that I could have found that formula somewhere and probabbly figured it out lol. But that sounds about right I suppose.
Now. For part two of my question.. Does anyone know which vehicles use a scroll type ac compressor? I have heard that the Trailblazers do but am not sure. And they must be on other vehicles as well. Anyone got anything?
anderkart
Surprise Arizona USA
Are you thinking about using a scroll type A/C compressor as a supercharger for your Briggs?
I did a little google searching and found several of the newer Ford, Mitsubishi, Honda's are all using scroll type A/C compressors nowadays. Check out this search link: http://www.google.com/search?q=scro...6B6ztiQLD64CoBw&ved=0CDsQsAQ&biw=1024&bih=532 You can click on those pics to get info about what model cars they came on :thumbsup:
Jimmy_B
There was a guy in MN back in the late 90s that was building super chargers for B & S motors. He bugged me for more than a year to run his stuff and test for him. Unfortunately, we weren't allowed to use them. Don't know what market he was shooting for since no sanctioning bodies allowed them as far as I knew at the time.
I might still have his information around somewhere.
DeathStarr89
Loose Nut
Davenport, Iowa
I'm pretty close to having my Briggs flathead adapter done for my flow bench, i can get you actual numbers pretty soon.
Both blocks i have are ported but the numbers shouldn't be too far off from a stock one.
The A/C S/C thing sounds interesting... been looking for a way to get some more power out of my flatheads.
jamyers
Buffalo Gap, TX
How did I do?
I'd say pretty darned well! :cheers2:
I'll go a half-step further...a Briggs 5-hp would flow 13.09 cfm at 3600 rpm at 100% Volumetric Efficiency (VE), and there's the unknown. Most stock automotive engines flow 80% VE, all out naturally aspirated race engines at 100%.
I'm curious what the VE on a stock Briggs flatty is - I'd guess somewhere around 55-60%, just a guess...
Which is why one ought to respond very well to supercharging - get the VE up over 100% and you've effectively doubled the displacement of the engine!
falcon52
Wow!
@anderkart - Yes I have been thinking of a way to make a croll compressor into a s/c. I've read up a lot about it and it's not looking promising but it would be a neat project. The only problem I am having is in theory I can get all the PSI I want out of it but its low cfm psi. Most ac high side systems are near 200+ psi. Trouble is, you need both for forced induction.
@deathstar - That sir, would be fantastic! Real numbers would be a good thing to know for anyone messing with these.That would be a phenomenol help!
If anyone can aid in finding cfm numbers for a specific or even general numbers for scroll compressors please post it up. I have been looking and researching with autozone and other places but they never say what cfm of the compressor. The York 210 edc (non scroll) is the only one that shows a number and it is about as big as the briggs itself lol.
And the reason I was looking into a scroll type compressor is
-they are neat as hell
-they have fewer moving parts (means will need less oil)
-and are more efficient in delivery and in flow
I have a whole system drawn up on my dry erase board lol.
jamyers
Buffalo Gap, TX
The problem with using an a/c compressor is that most are designed to be lubed by oil in the refrigerant - which means you'd have to feed oil into the intake to keep from killing the compressor.
