My briggs and stratton is starving for fuel, it will only run if I put fuel on the plug. I've cleaned out all the carb pipes and everything seems to be clean. I'm not sure if my diaphragm is working properly because I know nothing about it. Also, does the governor have to be attached in order for the engine to work properly?
If so then I have no idea how to properly attach it,
and is it the small hinge/bolt on the lower side of the engine?
