to un flood it take out the spark plug put a match in the spark plug hole and jump back
(its better than waiting)
One sure clue about flooding is if you see fuel dripping from the air cleaner when you're trying to start, and you notice a strong odor. When it floods you should open the throttle all the way, with the choke off, and pull the rope. That could get it to start firing. If it starts sputtering at that point, keep going until it starts.
If it's flooded really badly remove the spark plug, open the throttle and pull the rope to spin the engine quickly until you clear out all the extra gasoline. You should be able to smell it if there's a lot of extra gasoline fumes coming out. When you think it's all cleared out put it back together and crank it again and see if it starts.
My 49cc engine floods from time to time, so my policy is that if the engine is not running the fuel valve is OFF! I open it only when it's time to run the engine.
also if its harder to pull than first attempt, thats a dead give-away that its flooded.
That's not flooded, that's called a stuck metering lever.
