500cc sled engine
Deadeye
Newguy
Southeast PA
So I just bought a '79 Artic Cat Pantera 5000. It has good compression. The carb is reasonably clean, and the spark plugs are new. However, when I yank the cord, there is no spark at the plugs. The headlight does light up a little though. I have a feeling it could be the CDI. But they aren't cheap, and I don't know what years to look for at the junkyard that will fit my engine.
So basically I'm asking you guys for help. I'd like to know what to check before I rule everything else out and buy another CDI. I should add, that most electrical terminology confuses the hell out of my pea brain. So if you could dumb it down slightly, that would be cool. :D
Thanks
Deadeye
Newguy
Southeast PA
For some reason, the guy it from said they were known to go bad so he bypassed it. The 2 wires are now just twisted together. I tried to start it with the wires apart, still no spark at the plugs.
Jake.B
California-USA
Im not to sharp on electric, but if the wires that are connected for bypassing are grounded out it wont spark correct? I would make sure they are not grounded.
Bluethunder3320
id look for any wiring that could be faulty or weathered... i had a Kawasaki 3 wheeler and i (thought) i disconnected the kill switch, but it wasnt, i plugged it back in and i had spark.
also the actual spark plug wire was cracked so i replaced that from a lawn mower, it worked.
Deadeye
Newguy
Southeast PA
I am still looking for the problem. No luck so far. I need to have some one come look at it who knows wiring and such.
