Budget GoKart
Aka a kenbar
How the heck... That would take a hit hard enough to kill someone... now that i think about it they probabaly jumped it. Also have you inspected under the engine plate?
7thofa2nd, I believe it was the first page and the first time the robron was mentioned, the supports for the front axles that are present on your robron don't exist on his kart and there is no live axle either. As I stated early on, everything about this kart screams MANCO! Also I believe it to be a 400 series of some sort i.e. 400-405, it's just too close to manco style and nothing about it seems to be a vintage race kart like the robron or the yellowjacket mentioned earlier.
We've had the argument here before about that same style, kelch corp steering wheel, they used those on many many karts, and riding mowers. I apologize for being a bit explosive, seemed everything i had said was blatantly ignores and the opposite was suggested, started to appear obvious.
With all that behind us, the following reasons are why I strongly believe it's a manco that's been beat on, the pedals are typical manco, wheels from what I've seen look like 5"manco split wheels, frame style very closely matches the 400 I built for the kids, steering wheel was common on manco along with a list of others, the bar that has been cut off the back is a support for the original seat frame and it's the same location as the 400.
If I'm correct, the O.P. wants to install a gx270 and the rear of the frame shouldn't fit a big block without some modifications because it's a very small kart. The dead axle only providing power to one wheel could also be problematic, torque steer, no traction, too much stress on the frame from the big block, and so-on. If a big block is being shoe-horned into that frame I personally wouldn't do it without a live axle, and a lot of frame support, my gx270 is capable of bending steel and I had to reinforce the way I built the jackshaft for it, and that kart is way bigger and heavier, still torque steers and it's fast enough I'm basically afraid of it. I still think a 212 or similar is more than plenty for that little kart, then find another $50 deal on a bigger, beefier frame for the gx270.
Karl did...he put 20hp on 1wd i think
it worked 270 is great. just got a new sprocket. am I in the build off, did I do it rite and is there anything else I need to do?
