5 hp briggs problem
tundrabeagle3
Ca
My 5 hp briggs has been bogging out when it goes to its top speed at wot not sure if its an engine problem. what do you guys think?
scarletvw
Minnesota
Sounds like it might be a carb tuning issue, also look at if the engine has any leaks at the gaskets. My 3hp briggs had a leak in the gasket from the carb to motor, would cause bogging and poor idle.
Start the motor and then spray carb cleaner around all of the gaskets, if the idle changes like jumps up or drops down when you spray somewhere, that means there is a leak.
tundrabeagle3
Ca
i cleaned the carb, put new gaskets and diaphragm. it fixed the problem of it dying when i give it gas but now it bogs out when it hits its top speed governor is removed. and it only hitting about 5000 rpms.
scarletvw
Minnesota
Do you have a billet flywheel and internals? 5000rpm out of a briggs is getting up to a dangerous area if the engine isn't built for it.
tundrabeagle3
Ca
the plug is black, its been doing this since ive owned it its a cat 250 with the stock gearing, i also put a bunch of motor oil in to make sure it doesnt seize up again. i notice when it bogs out that smoke comes out of the exhaust .
scarletvw
Minnesota
You've got too much oil in it because you've siezed it before and its belting out smoke out of the exhaust? :roflol:
tundrabeagle3
Ca
yup better safe than sorry its a different block and only smokes when it boggs out at full throttle
Wait a minute. I got lost. You've siezed THIS engine, or another one?
Too much oil is a problem.
What colour is the smoke?
A black, wet oily plug is oil fouling. Black and dry is too rich.
tundrabeagle3
Ca
it was seized so i took the crank, carb and flywheel and put it in a another briggs block with good cylinder walls and piston, the spark plug is black but i did lay the bike down and it burned oil but never turned off. i just rode it a couple of hours and it ran like a champ but i didnt stay full thottle for long .
tundrabeagle3
Ca
i fixed the rich problem with a longer needle, but it died again today. it was running good before I went to lower gearing and i was going up a hill when the bike turned off . it wouldnt start again not sure what happened what do you guys think?
