I got an old 5 hp Briggs engine. 136212-1026-E1
The engine will not idle. This model does not have an idle mixture screw. It has a brass screw called a high altitude jet. Its seated all the way in and has a hole in the tip. See http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=mssAIN-K_ny7tH217FzoPu on page 14, it says "The idle mixture valve on this engine is not adjustable".
I have the idle speed screw on the throttle plate screwed all the way and it still does not hold the throttle open wide enough to allow it to run.
I have replaced ALL of the gaskets on the carb and tank. I have cleaned out all of the carb including removing the welch plugs and using a tip cleaner to clean all of the ports. Also used carb cleaner to ensure all ports are open and free flowing.
The both intake tubes are clean with no buildup over the screens.
New spark plug.
A bit of history of my pain and suffering. It got the engine and started it up, it ran with a ROUGH idle occasionally stalling out when the throttle was let up. Backfired ALOT when the throttle was let up also. It ran extremely fast and I finally figured out the governor spring was missing. I put a spring on and it still had the exact same symptoms. I read how to adjust the governor (pushed arm down to WOT, and turned governor shaft clockwise and tightened back down), and did that. Now it won't start on idle and when revved up it surges, although it doesn't seem to be going past 3600 (just a guess from the sound, and half throttle plate opening).
I included a few pictures for reference. I am not small engine person, but pretty handy around the house. This engine is causing me a lot of frustration!
New spark plug.
