5 horse 2 stroke vertical shaft ?????
timbecht
i have a very good lawnboy 5 hp 2 stoke motor besides remounting the carb what else do i need to do to run it horizontal shaft for my kart project
if you run a set up like this please post some pics for me also thanks in advance
or any info on doing this set up would be great and thanks again
Jerryburger
Admiral Annoy
The Nation's Catbox...er, AZ.
Russ has threads on this (check the search option) and it mostly involves rotating the carb to the right orientation, making a mount, finding a clutch or drive that'll fit the output shaft. I have a Briggs 2-stroke, and so far, rotating the carb was the easy part.
timbecht
here they are russ
